SFP module compatibility list for Hero (KN-1012)
Keenetic Hero 2nd generation (KN-1012) are equipped with an SFP port to connect to Gigabit Ethernet networks via fibre optic cable.
An SFP module (transceiver) is purchased separately!
NOTE: Important! The speed of optical line connection via SFP module depends on the ISP's equipment and settings. Possible options: 100, 1000, 2500 Mbit/s. Giga (KN-1012) only supports 1000 and 2500 Mbit/s. If your operator uses 100 Mbit/s, the connection will not work even if the SFP module is in the list of supported models.
Below is a list of modules which functionality was tested in our laboratory or reported by customers.
Vendor
SFP Model
Speed
Technology
Osnovo* SFP-S1SC13-G-1310-1550-I 1 Gbit/s Ethernet
Osnovo* SFP-S1SC12-G-1550-1310 1 Gbit/s Ethernet
Osnovo* SFP-TP-RJ45(1G) 1 Gbit/s Ethernet
Eltex NTU-SFP-100 1 Gbit/s GPON
Atop APSB35123CDS20 1 Gbit/s Ethernet
Atop AP-B35121-3CS3 1 Gbit/s Ethernet
MlaxLink* ML-10T 1 Gbit/s Ethernet
MlaxLink* ML-SG-3WDS-31SD 1 Gbit/s Ethernet
MlaxLink ML-SG-3WDS-LB31S 1 Gbit/s Ethernet
SNR SNR-SFP-W35-20 1 Gbit/s Ethernet
Gigalink* GL-OT-SG14SC1 1 Gbit/s Ethernet
Gigalink*
GL-OT-SGRJ45 1 Gbit/s Ethernet
Gigalink* GL-OT-SG08SC1-1550-1310-D 1 Gbit/s Ethernet
Gigalink* GL-OT-SG08SC1-1310-1550-D 1 Gbit/s Ethernet
Upnet* SFP-G-03SC 1 Gbit/s Ethernet
D-Link* DEM-310GT 1 Gbit/s Ethernet
D-Link* DEM-330T 1 Gbit/s Ethernet
FoxGate* SFP-1SM-1310nm-3SC 1 Gbit/s Ethernet
QTECH* QSC-SFP20GEW-5531-DDM 1 Gbit/s Ethernet
QTECH* QSC-SFP20GE-1310-DDM-I
1 Gbit/s Ethernet
MultiCo* SFP-1000B 3KM SC WDM Tx1550 1 Gbit/s Ethernet
MikroTik* S-85DLC05D 1 Gbit/s Ethernet
MikroTik*
S-53LC20D 1 Gbit/s Ethernet
MikroTik* S-GPON-ONU
1 Gbit/s GPON
MikroTik* S-RJ01 1 Gbit/s Ethernet
Cisco* GLC-LH-SM 1 Gbit/s Ethernet
Cisco* SFP-GE-T EXT 30-1421-01 1 Gbit/s Ethernet
OptTech* OTSFP-LX-D 1 Gbit/s Ethernet
Gateray*
GR-S1-W553S-D 1 Gbit/s Ethernet
Gateray* GR-SFP-ONU 1 Gbit/s GPON/EPON
Huawei*
OptiXstar MA5671A 1 Gbit/s GPON
HS Fiber Communication (HSGQ)*
SFP ONU EPON STICK DFP-34E-2C2 1 Gbit/s EPON
HS Fiber Communication (HSGQ)* SFP ONU GPON STICK DFP-34G-2C2 1 Gbit/s GPON
Alphabox* SFP T1310/R1550nm 3 KM SC 1 Gbit/s Ethernet
SNR* SNR-SFP-ONU-XPON 1 Gbit/s GPON/EPON
SNR* SNR-SFP-W53-3 1 Gbit/s Ethernet
ODI XPON ONU STICK DFP-34X-2I3 1.25/2.5 Gbit/s GPON/EPON
ODI XPON ONU STICK DFP-34X-2IY3 1.25/2.5 Gbit/s GPON/EPON
ODI GPON ONU STICK DFP-34G-2C2 1.25/2.5 Gbit/s GPON
ODI XPON ONU STICK DFP-34X-2C2 1.25/2.5 Gbit/s GPON/EPON
ODI* XPON ONU STICK DFP-34X-2C 1 Gbit/s GPON/EPON
ODI* XPON ONU STICK DFP-34X-2C3 1.25/2.5 Gbit/s GPON/EPON
CareLink* CL-SFP-WDM-20-31SC 1 Gbit/s Ethernet
ComOnyx*
CO-SFP-SCG20-1513 1 Gbit/s Ethernet
ComOnyx* CO-SFP-SCG20-1315 1 Gbit/s Ethernet
ComOnyx* CO-SFP-LCG20-1513 1 Gbit/s Ethernet
ComOnyx* CO-SFP-LCG20-1315
1 Gbit/s Ethernet
ComOnyx* CO-PSFP-LC1G/20-P506 1 Gbit/s Ethernet
ComOnyx* CO-PSFP-LC1G/20-P507 1 Gbit/s Ethernet
Ubiquiti*
SFP UF-RJ45-1G 1 Gbit/s Ethernet
Ubiquiti* UF-MM-1G 1 Gbit/s Ethernet
Ubiquiti* UF-MM-10G 1 Gbit/s Ethernet
Ubiquiti* UACC-OM-MM-1G-D-2 1 Gbit/s Ethernet
XBIT* SFP-WDM-1G-03-55B-S
1 Gbit/s Ethernet
XBIT* SFP-WDM-1G-03-31A-S
1 Gbit/s Ethernet
C-Data CDT FD511GX-RM0 1.25/2.5 Gbit/s GPON/EPON
C-Data CDT SNR-SFP-ONU-XPON 1.25/2.5 Gbit/s GPON/EPON
C-Data* XPON SFP ONU STICK FD511GX-RM0 1 Gbit/s GPON/EPON
CTS* SFP-31W2Bah
(SM-10)
1 Gbit/s Ethernet
Gateray*
GR-S1-W313S-D 1 Gbit/s Ethernet
FIBO* SFP-1G-T RJ45 1 Gbit/s Ethernet
FIBO* FT-S1-RJ45 1 Gbit/s Ethernet
FIBO* FT-S10-AOC2m 2.5 Gbit/s Ethernet
Fibertrade*
FT-SFP-WDM-1,25 1 Gbit/s Ethernet
JT-COM*
JT-C1GE-R01 1 Gbit/s Ethernet
Netmod* SFPXBR2GR (DFP-34X-2C2) 1 Gbit/s GPON/EPON
TP-Link* TL-SM331T 1000BASE-T RJ45  1 Gbit/s Ethernet
V-SOL* ONU XPON V2801F 1GE SFP 1 Gbit/s GPON/EPON
Step4Net* SFPd-03-1310-WDM-SC 1 Gbit/s Ethernet
Step4Net* SFPd-03-1510-WDM-SC 1 Gbit/s Ethernet
Optronic*
TBSF15-3-12gLC-3c-DD 1 Gbit/s Ethernet
InfoTech*
SFP-WDM-GE-SC20D 1 Gbit/s Ethernet
Ericsson* RDH 102 47/2 R2A (RTXM192-406-C24) 1 Gbit/s Ethernet
Huawei* MXPD-243S 1 Gbit/s Ethernet
Huawei* RTXM191-400 1 Gbit/s Ethernet
Zyxel* PMG3000-D20B 1 Gbit/s GPON
* — Information was provided by users.
NOTE: Important! There are no restrictions in Keenetic routers that allow only specific models of SFP modules to be used. You can install SFP modules from any manufacturer that meets the SFP industry standard and supports 1 Gbit/s or 2.5 Gbit/s transfer rates.
Make sure to ask your ISP for information about the possibility of connection via a particular SFP module!
The transmitting and receiving wavelength characteristics used in the SFP module are also important. For example, if your ISP uses a single-mode optical cable and a module with 1310nm/1550nm wavelength, the other module must be 1550nm/1310nm. This information can be obtained ONLY from your ISP. This information is also relevant for point-to-point connection using single fibre Ethernet SC/LC SFP modules.
Before purchasing and using GPON/GEPON modules, you must be sure they are compatible with the ISP's equipment, which you can ONLY find out from the ISP itself.
PON and Ethernet technologies use different media access principles. The transmission medium itself is the same - fibre optics.
PON is a TDM (Time Division Multiplexing) technology; the devices use a transmission medium bandwidth based on TDMA (Time Division Multiple Access).
Ethernet uses CDMA/CD (Carrier Sense Multiple Access with Collision Detection), i.e. access to the transmission medium of each device is at a conventionally random point in time, while in PON, it is at strictly defined time slots.
Special PON termination equipment (ONT/ONU) is needed to connect PON devices to the Ethernet network. Keenetic has an SFP Gigabit Ethernet port. But there is a G(E)PON ONT/ONU in the SFP module form factor. Externally, it is not much different from a simple SFP GigabitEthernet module, but the module itself is noticeably larger.
If you use an SFP module that is not on our list, please let us know in the comments to this article or contact our Technical Support Team. We will gladly add it to the list.
7 out of 7 found this helpful
