Dev build KeeneticOS 3.3 Alpha 3 of 14-09-2019.
Resolved Issues & Improvements
- HTTP: fixed port redirection to "This Keenetic"
- HTTP: added "Secure" flag to the Set-Cookie header in SSL sessions
- HTTP: added X-Frame-Options "DENY" header
- HTTP: implemented SSL server autostart unless otherwise configured:
ip http ssl no enable - VPN: fixed Android connection failure with the following symptoms:
- ppp-pptp: fsm timeout
- ppp: compressor dropped pkt
- DNS: fixed DNS-over-HTTPS for "ip policy" members
- USB: fixed USB-Ethernet adapters support
- fixed "auto" static routes with the explicit gateway address
- ACME: fixed compatibility with the new Let's Encrypt CDN
- OpenSSL updated to 1.1.1d
Comments
Article is closed for comments.
