Draft version KeeneticOS 3.4 Alpha 9 of 19-03-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
- implemented ping-check interface restart:
- interface {name} ping-check restart [interface] — enable {interface} restart (optional argument defaults to {name})
- ping-check {name} restart-interface — obsoleted
- Wi-Fi: fixed the 20/40/80 MHz bandwidth setting for mt7615
- Wireguard: reduced the default MTU size to 1324 bytes
- OpenVPN: removed redundant hosts from the device list
- Web: fixed DSL connection priority setting
