KeeneticOS 3.4 Alpha 11
Draft version KeeneticOS 3.4 Alpha 11 of 27-03-2020.
You can find instructions on how to install the Draft version in the developers' forum  Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • Wi-Fi: implemented Kr00k protection (CVE-2019-15126)
  • L2TP: fixed control connection shutdown
  • L2TP: fixed source port change on reconnection
  • VPN: fixed communication between clients of different VPN services
  • IPsec: fixed tunnel traffic accounting
  • IPsec: fixed IP alias support
  • IPsec: fixed scheduled tunnel connection
  • Web: fixed directory access control configuration
  • Web: fixed Release notes reference
  • Web: fixed unregistered traffic monitoring in a separate tab
  • OpenSSL: updated to 1.1.1e
4 out of 4 found this helpful
