KeeneticOS 3.4 Alpha 12
Draft version KeeneticOS 3.4 Alpha 12 of 29-03-2020.
You can find instructions on how to install the Draft version in the developers' forum  Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • improved internet checking algorithm:
    • reduced the number of simultaneous connections
    • enabled sequential polling of test servers
    • enabled dynamic polling interval
  • fixed "SSL_read() failed" error on extenders
2 out of 2 found this helpful
