Draft version KeeneticOS 3.4 Alpha 13 of 02-04-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
- Wi-Fi: fixed Class-2 error handling for backhaul connections
- TSMB: added Change Notification support
- Web: fixed configuration saving for ICMP-based ping-check interfaces
- OpenSSL: updated to 1.1.1f
