Draft version KeeneticOS 3.5 Alpha 13 of 10-07-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
- enabled active packet queue management in the trafficcontrol module;
- SoC: fixed MAC address entry lookup;
- exFAT: fixed big-endian specific errors;
- USB: supported modems:
- E3372h-320
- Anydata W150
- HTTP: implemented X-Frame-Options header configuration:
ip http proxy {name} x-frame-options {x-frame-options}
- Wireguard: updated to 1.0.20200623.
Attention: deployed the new firmware signing certificate to the cloud infrastructure. Previously saved firmware files can be uploaded using the TFTP recovery only.
