KeeneticOS 3.5 Alpha 16
Draft version KeeneticOS 3.5 Alpha 16 of 01-08-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • IPsec: enabled partial hardware acceleration of AES CTR/CCM/GCM on mt7628;
  • HTTP: implemented a separate security-level setting for HTTP proxies:
    • ip http proxy {name} security-level (public | private)
  • NTFS: implemented sparse file support;
  • TSMB: added "hidden" and "system" attributes to dotfiles;
  • USB: added Quectel EG12/EM12 modem support;
  • Netflow: implemented protocol version setting:
    • ip flow-export version {version}
  • Web: added "File system" column to the USB storage table;
  • Web: added HTTPS option to HTTP proxy settings;
  • Web: added a description field to static routes;
  • Web: added TCP+UDP network rules support;
  • Web: fixed alignment of question marks;
  • transmission: fixed the "Enable download sequential" checkbox.
5 out of 6 found this helpful
