KeeneticOS 3.5 Alpha 17
Draft version KeeneticOS 3.5 Alpha 17 of 08-08-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • SSTP: fixed "do_page_fault() SIGSEGV" error;
  • Web: fixed a fatal error on the dashboard if the 'cloudcontrol' component is not installed;
  • Web: added 3G/4G mode selector for UsbLte interfaces;
  • transmission: implemented NTFS sparse file support;
  • transmission: updated the web interface.
4 out of 4 found this helpful
