Official release KeeneticOS 3.5.1 of 07-10-2020.
To install the latest version, update the Keenetic from web control panel.
New Features & Improvements
Implemented active packet queue management for DSL and LTE connections
Implemented isolation of service class-based packet flows
Implemented assignment of service classes to registered
Enabled active packet queue management in the trafficcontrol module
MWS: added "ip http security-level" synchronization
MWS: enabled 2.4 GHz backhaul for all extenders in a single-band controller network
Wi-Fi: implemented WPA3-PSK Fast Transition (FT-SAE)
Wi-Fi: implemented binding to 2.4/5 GHz band
DNS: added CloudFlare internet filter
USB: added MTS 8810FT, Quectel EG12/EM12, Anydata W150, Huawei E8372h-320, Huawei E392u-12, Huawei E3372h-320 (A1 ISP), ZTE MF79, Alcatel IK40V v.01008, Alcatel IK41V, ALTEL 4G Wingle Model W02, HP lt4220, Foxconn T77W676, Telit ln940 modems support
USB: added exFAT filesystem support
USB: fixed Anydata W140 network scanning procedure
USB: increased descriptor read tolerance for storage devices
TSMB: implemented LsarQueryInformationPolicy RPC support
TSMB: added "hidden" and "system" attributes to dotfiles
IPsec: imlemented IKEv2 client
IPsec: implemented IKEv2 VirtualIP server based on a Let's Encrypt certificate
IPsec: implemented Virtual-IP VPN client traffic accounting
IPsec: added an ESP ALG component
IPsec: added AES-CTR mode to IKE and ESP (EIP93 hardware accelerated)
IPsec: added DH groups to IKE and ESP: x25519, x448, ECP 192/256/384/521
IPsec: added AEAD ciphers to IKE and ESP: AES-CCM and AES-GCM (EIP93 partially accelerated), CHACHA20-POLY1305
HTTP: implemented a separate security-level setting for HTTP proxies
HTTP: implemented randomized session cookie names
HTTP: added HTTPS upstream support
Web: added 3G/4G mode selector for UsbLte interfaces
Web: added "TCP/UDP" protocol option for NAT rules
Web: added language packages
Web: added "File system" column to the USB storage table
Web: added HTTPS option to HTTP proxy settings
Web: added a description field to static routes
Web: added a combined security mode "WPA2 + WPA3 Enterprise"
Web: added a description field to firewall rules
Web: added remote access configuration for extenders
Web: added IKEv2 server configuration page
Web: added SMS support for QMI modems
Web: added VLAN-over-PVC support
Acme: improved SSL certificate revocation and renewal task queue
Wireguard: updated to 1.0.20200623
DSL: updated PTM/SAR driver
Transmission: updated to 3.00
Transmission: updated the web interface
SSTP: improved compatibility with AnyVPN SSTP Connector
Resolved Issues
- Fixed unregistered traffic accounting
- Wi-Fi: fixed WPA Enterprise authentication for hidden SSIDs
- Wi-Fi: fixed WISP traffic accounting
- TSMB: fixed unauthorized NetShareEnum response
- SoC: fixed IGMP snooping on the mt7621 integrated switch
- IGMP: fixed IGMP snooping in extender/repeater mode
- IGMP: fixed IGMP snooping when connecting switches cascade
Comments
