Draft version KeeneticOS 3.6 Alpha 3 of 28-10-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
- IPsec: removed obsolete code, optimized footprint;
- ACL: fixed removal of empty directories;
- NTFS: fixed hiding of files with "hidden" and "system" attributes;
- transmission: fixed error reading from the RPC socket;
- disabled device reboot by short pressing of the RESET button.
