Draft version KeeneticOS 3.6 Alpha 12 of 20-12-2020.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
- Wi-Fi: implemented PMK-R1 pool for sustainable WPA3 FT roaming;
- DSL: more detailed diagnostics, test run time increased to 7 minutes;
- LED: inverted power down schedule:
system led shutdown {mode} schedule {schedule}— obsolete setting, do not use;- system led power schedule {schedule} — LED power up schedule;
- system led power shutdown (front | back | all) — LED shutdown mode.
- HTTP: implemented Host header enforcement:
- ip http proxy {name} force-host {force-host}
Comments
Article is closed for comments.
