Draft version KeeneticOS 3.6 Alpha 16 of 14-01-2021.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
- IPsec: implemented EAP-PEAP authentication for IKEv2 client and server;
- IPsec: enabled aes256-sha256-modp2048 for compatibility with Proton VPN;
- IPv6: improved IPv6 address detection for automatic whitelisting;
- HTTP: fixed writing small files (less than 64 KB) via WebDAV;
- USB: fixed spontaneous reboots when using Huawei CDC NCM modems;
- LTE: fixed use of QMI connections in additional "ip policy" profiles;
- DSL: fixed blocking of the packet queue when G.Vector is active;
- DSL: added versions of internal components to the "Diagnostics" page.
