Which Keenetic models are suitable for the Mesh Wi-Fi System?
Mesh Wi-Fi works with all current Keenetic models (with a KeeneticOS version 3.1 or higher). Any model can act as the controller (Main Router) of your Keenetic Mesh Wi-Fi System or an extender, except for the Keenetic Buddy models, which only act as an extender.
Always choose a more advanced router, like a gigabit model or the one with USB ports as your Main Router. If your Internet tariff is higher than 100 Mbit/s, the Main Router should be a gigabit model like Skipper, Titan, Hero DSL or Hero 4G. As Wi-Fi range extenders to it, you can choose Speedster or Explorer models equipped with an operating mode selector on the case for quick adding to the Wi-Fi System without preconfiguring. It makes sense to use Speedster as an extender for a wired connection to the gigabit Main Router and Explorer for a Mesh Wi-Fi connection. Alternatively, compact Wi-Fi range extenders, Buddy 5/5S, which plug directly into an electrical socket, can be used to extend the coverage of your Wi-Fi System. You can use the Voyager Pro and Orbiter Pro ceiling-mounted access points (PoE-powered models) to extend Wi-Fi coverage in your office network.
Extenders with gigabit ports are very desirable to connect with a wire. It is not even necessary to stick to the 'star' topology, you can use a daisy chain connection.
If your Internet tariff is up to 100 Mbit/s, and you do not plan to change it for a higher speed, you can choose Keenetic Carrier as the Main Router and add one or more Explorer or Buddy 5 models as extenders.
Connecting over the air to get a Mesh network is most effective in dual-band models of the same or close Wi-Fi class and especially 100 megabit models because a 5 GHz backhaul connection is likely to be even faster than over cable. For example, ideal kits start with Carrier while adding the necessary number of Explorers or Buddy 5.
If you rely entirely on Mesh Wi-Fi rather than wire, it is advisable to limit the maximum number of Keenetic devices on the network to five, including the Main Router. In most cases, models with the same port and Wi-Fi network speeds will suffice. But when it is not the gigabit Ethernet and Wi-Fi speed that is important, but the budget and the coverage area, the low-cost dual-band model Keenetic Explorer (KN-1611), or even single-band Starter (KN-1111) will do. Two entry-level routers can easily turn into a Mesh Wi-Fi System with seamless roaming, WPA3 security, network segmentation, and centralized management.
For a Wi-Fi System with the latest Wi-Fi 6 (802.11ax) standard, use the AX class Wi-Fi models. For example, Titan (KN-1811), Hero (KN-1011), Hero 4G+ or Hopper models will work as the Main Router, and Sprinter or Voyager Pro models as an extender.
62 out of 66 found this helpful
