Official release KeeneticOS 3.6.1 of 11-03-2021.
To install the latest version, update the Keenetic from web control panel.
New Features and Improvements
KeenDNS moved to a separate component 'ndns'
Fixed configuration output that exceeds the size of 65639 bytes
Fixed a bug with mounting an exFAT partition formatted in the MiniTool Partition Wizard
MWS: implemented limiting of a working zone for wireless devices
MWS: implemented a unique MAC address of the device in additional network segments
MWS: implemented sharing of timezone configuration with extenders
MWS: enabled PMF security for backhaul connections
MWS: implemented backhaul rescanning when a new extender is detected
MWS: improved a backhaul access point selection algorithm
MWS: fixed traffic forwarding between mt7613-based wireless extenders (KN-1611, KN-1711, KN-3010)
Wi-Fi: implemented PMK-R1 pool for sustainable WPA3 FT roaming
LTE: implemented 'Data usage & limit' for KN-2210, KN-2310
DSL: updated the DMT firmware version to 5.10.6.2
DSL: more detailed diagnostics
USB: added support for the modems Megafon M150-4, Alcatel L100V, DW5821e (T77W968)
HTTP: implemented Host header enforcement
PPPoE: implemented Ethernet link restart after multiple PADO timeouts
IPsec: implemented EAP-PEAP authentication for IKEv2 client and server
IPsec: enabled aes256-sha256-modp2048 for compatibility with Proton VPN
- DNS: added ability to fully capture DNS transit traffic and wrap it on the router via the command 'dns-proxy intercept enable'
DNS: improved display of the DNS-servers list with multiple internet connections
DynDNS: added OpenDNS and DNS-O-Matic profiles
TSMB: fixed possible crash in processing non-unicode TREE_CONNECT_ANDX
TSMB: fixed possible crash with rename on case-insensitive share
Web: added extra diagnostics of the DSL connection
Web: added service class selection for registered device
Web: added LED operation mode and schedule settings
Web: increased the limit of entries in ACL
Web: fixed a problem with binding a registered device to the connection policy
Comments
Merhaba ben. Keenetic extra dsl kullanıyorum bugün güncelleme yaptım 3.6.1 ama Türkçe yapamıyorum. Detaylı bilgi istiyorum teşekkür ederim . Birde keenetic uygulaması ile ulaşım sağlayamıyorum. Oturum açık ama cihazı çevrim dışı görüyor
Mail:osi_yorulmaz@hotmail.com
Osman bey selam,
Cihazınızda diller artık paket olarak sunuluyor. Lütfen aşağıdaki bağlantıdaki makaleyi inceleyerek cihazınızı Türkçe yapın. Daha fazla bilgi için bize destek@keenetic.com.tr üzerinden mail gönderebilirsiniz.
https://help.keenetic.com/hc/tr/articles/360020487040
