KeeneticOS 3.7 Alpha 8
Draft version KeeneticOS 3.7 Alpha 8 of 01-05-2021.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • NTCE: fixed cleanup of obsolete sessions which caused excessive memory consumption;
  • NTCE: fixed detection of SIP, RTP, and RTCP protocols;
  • USB: fixed swnat packet acceleration for cdc_ether devices;
  • USB: fixed usage of POCO M3 smartphones as LTE-modems;
  • HTTP: fixed access to the device by domain name from the local network;
  • Web: added support for "Password protected" mode in the KeenDNS settings;
  • Web: redesigned the "Access to web applications running on your network";
  • Web: added the "Auto" option for the KeenDNS operating mode;
  • Web: added the "Disconnect" checkbox for external QMI modems;
  • Web: fixed application category identification on the "Host traffic monitor";
  • DSL: updated KN-2410 DMT firmware version to 5.12.23.5;
  • Opkg: fixed mounting of the embedded "storage" partition after a system restart.
13 out of 13 found this helpful
