Installing OPKG Entware in the router's internal memory
Starting from version 3.7, for some Keenetic models, it is possible to write OPKG Entware to the UBIFS partition of the router's NAND flash memory, i.e. to the built-in memory of the router.
NOTE: Important! The information in this article is valid for current models: KN-1010/1011, KN-1810/1811, KN-1910, KN-2010, KN-2110, KN-2310, KN-2410, KN-2510, KN-2610, KN-2710, KN-3810, KN-3610 with the KeeneticOS version 3.7 and higher.
To support this feature, you will need to install the following components:
On the 'Applications' page under 'USB Devices', click on 'Internal storage' and then on the built-in storage partition. Create the install folder:
Copy the installation file mipsel-installer.tar.gz or mips-installer.tar.gz, depending on the device.
TIP: Note: For KN-1010/1011, KN-1810, KN-1910, KN-2310, KN-3810, and KN-2610, use the mipsel archive for installation — EN_mipsel-installer.tar.gz
For KN-2410, KN-2510, KN-2010, KN-3610 and KN-2110, use the mips archive for installation — EN_mips-installer.tar.gz
For KN-2710 and KN-1811 use the aarch64 archive — EN_aarch64-installer.tar.gz
In the router's command-line interface (CLI), select the system partition storage:/ to install OPKG Entware:
(config)> opkg disk storage:/
In the log, you will see the following entries:
Dec 7 10:49:42 ndm
Dec 7 10:51:23 ndm
Dec 7 10:51:23 ndm
Dec 7 10:51:23 ndm
Dec 7 10:51:23 npkg
inflating "EN_mipsel-installer.tar.gz".
Dec 7 10:51:29 ndm
Dec 7 10:51:29 ndm
Dec 7 10:51:29 ndm
Dec 7 10:51:29 ndm
Dec 7 10:51:29 ndm
Dec 7 10:51:29 ndm
Dec 7 10:51:31 ndm
Dec 7 10:51:32 ndm
Dec 7 10:51:34 ndm
Dec 7 10:51:35 ndm
Dec 7 10:51:35 ndm
Dec 7 10:51:36 ndm
Dec 7 10:51:37 ndm
Dec 7 10:51:41 ndm
Dec 7 10:51:42 ndm
Dec 7 10:51:43 ndm
Dec 7 10:51:44 ndm
Dec 7 10:51:45 ndm
Dec 7 10:51:46 ndm
Dec 7 10:51:48 ndm
Dec 7 10:51:49 ndm
Dec 7 10:51:50 ndm
Dec 7 10:51:51 ndm
Dec 7 10:51:53 ndm
Dec 7 10:51:54 ndm
Dec 7 10:51:56 ndm
Dec 7 10:51:57 ndm
Dec 7 10:52:00 ndm
Dec 7 10:52:01 ndm
Dec 7 10:52:03 ndm
Dec 7 10:52:04 ndm
Dec 7 10:52:05 ndm
Dec 7 10:52:06 ndm
Dec 7 10:52:07 ndm
Dec 7 10:52:08 ndm
Opkg::Manager: /opt/etc/init.d/doinstall: Info: Installing "opt-ndmsv2" package...
Dec 7 10:52:11 ndm
Opkg::Manager: /opt/etc/init.d/doinstall: Info: The "opt-ndmsv2" package has been installed.
Dec 7 10:52:12 ndm
Dec 7 10:52:13 ndm
Dec 7 10:52:14 ndm
Dec 7 10:52:16 ndm
Dec 7 10:52:17 ndm
Dec 7 10:52:23 ndm
Dec 7 10:52:24 ndm
Dec 7 10:52:24 ndm
Dec 7 10:52:24 ndm
Dec 7 10:52:28 ndm
Dec 7 10:52:29 ndm
Dec 7 10:52:29 ndm
Dec 7 10:52:30 ndm
Dec 7 10:52:31 ndm
Dec 7 10:52:32 ndm
Dec 7 10:52:32 dropbear[4223]
Running in background
Dec 7 10:52:32 ndm
Dec 7 10:52:32 ndm
Dec 7 10:52:32 ndm
Dec 7 10:52:32 ndm
Dec 7 10:52:35 ndm
Checking the access from CLI:
(config)> exec sh
Changing the password for the root user (default login is root, password is keenetic):
/ # passwd root
Changing password for root
New password:
Bad password: too weak
Retype password:
The password is changed. Updating the system:
/ # opkg update
/ # opkg upgrade
Now install the required OPKG package.
To uninstall the Entware OPKG, go to the command-line interface (CLI) of the router and disable the OPKG startup:
(config)> no opkg disk
Opkg::Manager: Disk is unset.
Then unmount the storage:/ system partition:
Delete the contents of the storage:/ system partition:
(config)> erase storage:
TIP: Note: If you have problems with mounting the partition or deploying the system, you can ask for help on our forum: https://forum.keenetic.com/forum/45-keenetic-community/
133 out of 185 found this helpful
