KeeneticOS 3.7 Alpha 11
Draft version KeeneticOS 3.7 Alpha 11 of 29-05-2021.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • TSO: enabled mt7621 Frame Engine fault protection against small TCP segments with MSS less than 16 bytes;
  • USB: disabled ARP gateway availability check for UsbLte modems;
  • USB: added support for MTS 8213FT (Huawei E5785Lh-22c) modems;
  • Web: added IntelliQoS 2.0* priority configuration page;
  • HTTP: fixed CVE-2021-23017 vulnerability.
13 out of 14 found this helpful
