Authentication
To log in to Keenetic RMM, go to rmm.keenetic.com.
Then, click “Log in | Sign up” to access the Keenetic RMM.
Login is performed through the unified user authentication service Keenetic Account.
If you do not have a Keenetic account, please refer to the Keenetic Account article.
NOTE: Important! Two-factor authentication (2FA) is available in Keenetic Account. Activating two-factor authentication is not mandatory. It is an advanced security feature, in addition to your regular login and password.
If you forgot your password, use the password recovery form by clicking on “Forgot password?”.
You can log in to your Keenetic account in several ways, choose the one that works best for you:
  1. Login and Password combination. Use your Keenetic Account e-mail as your login.
  2. Access via a previously created Google, Facebook or Apple account.
TIP: Tip: If you have a Google, Facebook, or Apple account, you can connect to Keenetic Account using one of these accounts instead of registering. In this case, the registration process will take less time, and you will not need to go through the e-mail confirmation step.
9 out of 14 found this helpful
