Routers importing
You can import devices registered in a Keenetic Account into Keenetic RMM. To import, click "Import routers" on the main page or in the sidebar menu:
Select the devices you want to import into the Keenetic RMM:
Once selected, click "Confirm". After the import is complete, all imported sites appear on the Sites page with the status “Confirmation of rights required”.
Click the "Confirm rights" button in the list of sites or in the context menu and enter the router login and password. This step should be done for each imported site.
After entering your login and password, click "Confirm". You will now have full access to the site's management and monitoring.
NOTE: Important! For using the Keenetic RMM, the KeeneticOS version of your Keenetic device should be 3.7.5 or higher.
Note that Extenders not registered in the Keenetic Account before are automatically covered by the warranty programme when a Main router of a Mesh Wi-Fi system is imported into the Keenetic RMM.
8 out of 9 found this helpful
