KeeneticOS 3.7 Beta 4
Draft version KeeneticOS 3.7 Beta 4 of 28-10-2021.
You can find instructions on how to install the Draft version in the developers' forum Keenetic Community. All questions about the Draft version are accepted on the specified forum.
Resolved Issues:
  • USB: added the ability to use multiple partitions with the same volume labels, such as "storage"
  • HTTP: improved brute-force protection for KeenDNS name in cloud mode
  • USB: added support for the following modems:
    • 4G LTE Cat4 DS Telecom DSA901
    • 4G LTE Cat4 Megafon MM200-1
    • 4G LTE Cat4 HP LT4120
  • Core: implemented progressive firmware update providing less memory consumption and reliable upgrade
  • MWS: fixed binding Wi-Fi devices to Mesh Wi-Fi system nodes to operate correctly with allowed Wi-Fi bands
  • MWS: fixed Wi-Fi bands open for connection to apply correctly when acquiring Mesh Wi-Fi System members
  • NTP: fixed Network Time Protocol (NTP) server response validation in certain conditions
  • Transmission: removed download speed limit for Keenetic Peak (KN-2710)
  • PPP: increased Server address value up to 256 characters for PPP-based VPN clients (PPTP, L2TP, and others)
  • PPE: fixed the Traffic monitor statistics to display correct information after changing settings on the WAN interface
  • Syslog: added hostname value to the payload of the syslog message when sending records to a remote server
22 out of 22 found this helpful
