300 Mbps is the maximum physical layer rate according to the IEEE 802.11n standard when connected to adapters using two spatial streams and a 40 MHz channel for receiving and transmitting.
With the support of 256-QAM (TurboQAM) modulation in the 2.4 GHz range, the maximum connection rate on the 802.11n standard can be 400 Mbit/s (this feature is implemented in new routers Keenetic Hero, Keenetic Titan and Keenetic Skipper).
Actual wireless network transfer rate varies depending on the characteristics and settings of client equipment, a number of clients on the network, obstacles in the signal path, as well as the presence of other wireless networks and radio interference on the same band.
150 Mbps is the maximum physical layer rate according to IEEE 802.11n standard when connecting to adapters that use one spatial stream and 40 MHz channel for receiving and transmitting (when using 20 MHz channel the speed will not exceed 72 Mbps).
To start with, many users are misreading the connection speed in Megabits per second (Mbps), which is displayed in the 'Speed' field on the 'General' tab of the 'Status' window of the wireless connection in Windows.
In a Keenetic router, you can see the current Wi-Fi connection speed of mobile devices through its web interface on the 'Device lists' page.
This number shows the channel rate between the router and the device (the connection rate at the physical layer that is currently used within the selected standard). And the actual data transfer rate will be about 2-3 times slower than the channel rate. For example, in the connection properties, you see the speed of 150 Mbit/s, and the actual data transfer speed will be about 50 - 60 Mbit/s. The difference between connection speed and actual performance is primarily due to a large amount of service data, wireless packet loss and retransmission costs. The actual rate also depends on the settings of the access point, the number of wireless client adapters simultaneously connected to it and other factors.
NOTE: Important! Device specifications indicate the connection speed in Megabits per second (Mbps), and in user programs (Internet browsers, download managers, torrent clients) the downloading speed is displayed in Kilobytes or Megabytes per second (KBps or MBps). These values are often mixed up.
To convert Megabytes to Megabits, multiply the value in Megabytes by 8. For example, if the Internet browser shows the download speed of 4 Mbytes per second, then to convert to Megabits, you should multiply this value by 8: 4 MBps * 8 = 32 Mbps.
To convert from Megabits to Megabytes, divide the value in Megabits by 8.
As we wrote above, not the actual data rate is displayed upon connection, but the channel rate.
The thing is that at each moment, the access point (router with the active access point) works with a single client Wi-Fi adapter from the whole Wi-Fi network. The data transfer takes place in half-duplex mode, i.e. in turn — from the access point to the client adapter, then vice versa and so on. The simultaneous, parallel process of data transmission (duplex) in Wi-Fi technology is impossible.
If there are two clients on the Wi-Fi network, the access point will need to be switched twice as often as if there were only one client, as the Wi-Fi technology uses half-duplex data transfer. Accordingly, the actual data transfer rate between two adapters will be half as slow as the actual maximum speed for one client (we are talking about data transfer from one computer to another through an access point over a Wi-Fi connection).
Depending on the distance of the Wi-Fi network client from the access point or the presence of various interferences and obstacles, the theoretical and, consequently, the actual data rate will change. Together with wireless adapters, the access point adjusts the signal parameters depending on the radio conditions (distance, obstacles and interference, radio noise and other factors).
Let's have an example. The transfer rate between two laptops connected directly via Wi-Fi is about 10 Mbytes per second (one adapter works in access point mode and the other in client mode), and the transfer rate between the same laptops but connected via Keenetic router is about 4 Mbytes per second. This is how it's supposed to be. The speed between two devices connected via a Wi-Fi hotspot will always be at least two times slower than the speed between the same devices connected directly to each other, as the bandwidth is the same and the adapters can only communicate with the hotspot in turns.
NOTE: Important! According to Wi-Fi Alliance requirements, wireless devices can automatically select the 20 MHz channel width mode in the 2.4 GHz band. Since most smartphones and tablets, and many inexpensive laptops as well, are equipped with Wi-Fi adapters using a single spatial stream (MIMO 1x1 / 1T1R, one antenna is responsible for both receiving and transmitting), in this case, they will operate at speeds up to 72 Mbit/s. Their Internet access speed will not exceed 40 Mbit/s.
At the same time, Keenetic routers in the 2.4 GHz band with two spatial MIMO 2x2 streams and a channel width of 40 MHz can provide a link up to 300 Mbit/s and real speed (under ideal conditions) up to 150 Mbit/s. It is not possible to fix the 40 MHz channel width mode in the router, as this is a recommendation of the standard. Otherwise, most customers will not connect. For higher speeds, use the 5 GHz range.
More information is available in the following articles:
- Ways to increase connection speed, bandwidth and stability of your Wi-Fi network
- What affects Wi-Fi networks? The possible sources of interference
- General recommendations for placing a Keenetic device for stable and high-quality Wi-Fi network operation
TIP: Note: Some users rely on popular online services (e.g. Speedtest or nPerf) to measure their actual Wi-Fi data transfer rate.
Please note that online services are designed to check the speed of the Internet channel. They do not show the actual connection speed between the Wi-Fi client and the router.
Comments
