The self-test system file contains full information about your Keenetic router (not including your passwords), diagnostic information, a log and the router configuration (user settings).
If you have problems with your router or connection to the Internet, you can send a self-test file to our technical support service for diagnostics.
To save the self-test file, go to the 'General settings' page. The 'System files' section contains files for managing and viewing information about your router.
Click on the self-test file entry and then 'Save to computer'.
Your web browser will download the file. If the 'Save file' window appears, specify the location (the folder to which the file will be saved) and click 'Save' or 'OK'.
You can open the self-test.txt file for viewing in any text editor.
TIP: Tip: A similar setting can be made from an Apple mobile device. For more information, please refer to instructions How to save the system file self-test.txt from the Keenetic device via iPhone/iPad?
Comments
