Connecting to a WireGuard VPN from Windows
Starting from KeeneticOS version 3.3, you can use WireGuard VPN to connect to the local network of the Keenetic router remotely.
First, you need to configure the WireGuard server on the Keenetic device. The following instruction shows the process: 'Configuring a WireGuard VPN between two Keenetic routers'. Then move on to the VPN client setup.
NOTE: Important! If you want to configure a Keenetic router as a VPN server, make sure that it has a public IP address and, when using the KeenDNS service, that it works in the 'Direct access' mode. If any of these conditions are not met, connecting to such a server from the Internet will be impossible.
Below is an example of connecting to a server from a Windows operating system, using Windows 10 1909 (19H2) as a reference.
To connect to the Keenetic WireGuard server on a Windows-based computer, you must download and install the WireGuard program from the official website.
1. Launch the program and click on the down arrow next to 'Add Tunnel' in the lower-left corner. Select 'Add empty tunnel... [Ctrl+N]'.
The configuration window for connection to the remote WireGuard server Keenetic - 'Create new tunnel' - will open.
NOTE: Important! Leave this window open, do not close it.
2. Download wg-client.conf file to your computer. You can save it to your Desktop. Open it in a text editor, for example, in Notepad++.
You will see a ready-made configuration in which you will need to enter the settings for the Windows WireGuard client [Interface] and the remote WireGuard server Keenetic [Peer].
3. Go back to the 'Create new tunnel' window of step 1 and copy the Windows WireGuard client private key to your computer clipboard from the 'PrivateKey =' field.
4. The copied WireGuard client private key must be inserted into the ready-made configuration from step 2 into the 'PrivateKey =' line.
5. Now, set up a remote connection on the previously configured WireGuard server side.
Connect to the router's web interface and go to the 'Internet' - 'Other connections' menu. Click on the previously created WireGuard connection ('WG-S') and then the 'Add Peer' button. Enter the name of the tunnel 'wg-windows-client' in the opened form of the peer settings.
In the 'Public key' field of the web interface, insert the Windows WireGuard client key from step 1, which should be copied from the 'Public key' field to the clipboard.
You can close the 'Create new tunnel' window, click 'Cancel'.
NOTE: Important! Leave the WireGuard connection window open, do not close it.
In the 'Allowed IPs' fields, specify the address from which traffic will be allowed to the server in IP/bitmask format — 172.16.82.6/32.
In the 'Persistent keepalive' field, specify the frequency of attempts to check the availability of the remote connection side. Usually, a 10-15 second interval between checks is sufficient. By default, the 'Persistent keepalive' value in peer settings is 30 seconds.
Click 'Save'.
6. Back to configuring wg-client.conf
[Interface]
PrivateKey = wAG52nyfQEEMOnt1W9Y4SdEOQB8XYaggenoUI6Thz3A=
Address = 172.16.82.6/24
[Peer]
PublicKey = 1YVx+x3C817V9YdhUtpUhzyDLVj5tnK2m//WjFGynm4=
AllowedIPs = 172.16.82.1/32, 192.168.22.0/24
Endpoint = enpwgwrkserver.dynns.com:16631
PersistentKeepalive = 5
Configuring the client [Interface]:
In the 'PrivateKey' field of the [Interface], you have already entered the Windows WireGuard client key in step 4.
Set the IP address in the 'Address' field of the WireGuard client in IP/bitmask format — 172.16.82.6/24 (internal tunnel address). It is possible to use a different subnet, choosing it from the private address range and avoiding overlapping with other subnets configured on these devices.
Configuring the server [Peer]:
In the 'PublicKey' field, insert the public key of the server, which can be copied to the clipboard from WireGuard settings in the web interface of the router:
In the 'Allowed IPs' field, enter the allowed IP addresses in IP/bitmask format — 172.16.82.1/32 (internal server address) and 192.168.22.0/24 (local segment address of the Keenetic router).
In the 'Endpoint' field, enter the public IP address or domain name of the WireGuard server and the listening port on which the WireGuard client will set the connection.
In the 'PersistentKeepalive' field, specify the frequency of attempts to verify the availability of the connection's remote side. Usually, a 10-15 second interval between checks is sufficient.
Press the Ctrl+S key combination or select the 'File' - 'Save' menu.
7. In the open WireGuard connection settings window from step 6, click on 'Import tunnel(s) from file' and select 'wg-client.conf' on the Desktop, and click on 'Open'.
8. After adding the 'wg-client' configuration to WireGuard, a new connection will appear in the 'Tunnels' list.
Click 'Activate'.
If the setting is correct, you will see a green indicator in front of the 'Status' line.
You can send ICMP packets to its IP address at the Windows command line to verify server availability.
Check the availability of the server web interface (in our example, it is a Keenetic with IP address 192.168.22.1).
The setup is complete.
If you want to allow the connected clients to access the Internet through this VPN connection, make an additional configuration from this article Internet access via WireGuard VPN.
Please note that on the VPN client side, in the wg-client.conf configuration file, in the '[Interface]' section, you need to specify the DNS server in the 'DNS=' field. In our example, the Google DNS server address is set to 8.8.8.8:
[Interface]
DNS = 8.8.8.8
[Peer]
TIP: Note: Provided that there is one peer in the configuration and the allowed network 'all addresses' is specified, the application will automatically generate a firewall rule on the computer that prohibits traffic past the tunnel.
The article Connecting a Windows 7 computer to a remote Keenetic network through the WireGuard tunnel presents another option when all traffic is routed to the tunnel, and the VPN client accesses the Internet through it.
46 out of 57 found this helpful
