On Keenetic Peak (KN-2710), Giant (KN-2610), Titan (KN-1810), Hero (KN-1010/1011), Skipper (KN-1910), Speedster (KN-3010), Peak DSL (KN-2510) and Hero DSL (KN-2410) if you don't use the WAN port (for example, you have a 3G/4G USB modem for an Internet connection or the router is in Extender Mode), you can use this port as a LAN port.
This setting can be done from the router's web interface by deleting the 'Wired' interface in the following way:
1. Assign the 'Provider' role for any of the free ports 1-4 (step 2 of the instructions Changing the operating mode and role of network ports);
2. Remove the 'Wired' interface (step 3 of the instructions Changing the operating mode and role of network ports);
3. Check on the 'Home segment' tab under 'Ports and VLANs settings' that port '0' is included in this network segment.
Note: It can also be done using the command-line interface (CLI). Make the following settings:
Login: admin Password: *************** (config)> interface Bridge0 include GigabitEthernet1 Network::Interface::Bridge: "Bridge0": GigabitEthernet1 included. (config)> system configuration save Core::ConfigurationSaver: Saving configuration...
The 'Wired' (ISP) interface will disappear from the web interface, and WAN port 0 can be used as LAN.
To get the WAN interface back, do the following setup:
Login: admin Password: *************** (config)> no interface Bridge0 include GigabitEthernet1 Network::Interface::Bridge: "Bridge0": GigabitEthernet1 included. (config)> system configuration save Core::ConfigurationSaver: Saving configuration...
The WAN interface will return with the previous settings and can be used as a WAN port.
NOTE: Important! To avoid errors when running the above commands, we recommend making this setting using the default configuration (i.e. after resetting the user settings to factory defaults).
Comments
Article is closed for comments.
