KeenDNS service error codes
The KeenDNS Cloud Service for remote access to network device management provides debug information in error codes.
Possible codes and corresponding action options are shown in the table below.
NOTE: Important! Because the remote connection cannot be established, you will need to switch to managing the router from the local network to eliminate the causes.
Message Code Reason Suggested solution
Internal server error 500
  • A (temporary) connectivity issue happened.
  • Please try reloading the page in your browser (Ctrl+R or F5 key).
  • If the issue persists, please contact the technical support providing the error code and, if possible, a self-test.txt file from the device.
Not Reachable 404
503
  • The router's off;
  • It has no Internet connection;
  • The Keenetic Cloud service is turned off;
  • The "Cloud-based remote control and KeenDNS" mandatory component is missing.
  • Please make sure that the Keenetic is plugged in with the supplied power adapter and that the status LED has a solid glow.
  • Examine the 'Internet' LED. An Internet connection must be established for the remote connection to work.
  • Keenetic Cloud service must be enabled in the System settings (Management menu section).
  • Accordingly, the 'Cloud-based remote control and KeenDNS' component must be installed.
Unknown Name 410
  • An error was made when entering the KeenDNS domain name in the browser.
  • Please check the registered Keenetic domain on the 'KeenDNS' tab in the 'Domain name' menu, the Network Rules section.
0x10 16
  • Internal error indication.
  • Please contact the technical support providing the error code and, if possible, a self-test.txt file from the device.
0x13 19
0x14
(Access Denied)
20
  • Remote access to the web interface of the device is set prohibited.
  • Remote access to the web configurator must be enabled in the "Users and access" menu.
  • Web interface port and TCP port 443 neither should be blocked by firewall settings nor redirected via the port forwarding options.
0x20
(Direct Only)
32
  • Attempt to access the device by IPv4 address over a cloud, while "Direct access" operating mode is set on the device.
  • It is obligatory that the correct access mode, Direct or Cloud, is set for the KeenDNS service. In case you want automatic recognition, use the 'ndns book-name {name} {domain} auto' command to register or update the KeenDNS registration, then just avoid selecting service operation mode in GUI.
0x21 33
  • An error that might occur when trying to access the device at IPv6 through the cloud, and IPv6 cloud access is disabled.
  • Please enable the Operating mode (IPv6) — Cloud access box in the "Network rules - Domain name".
0x22 34
  • IPv4 client address got incorrect.
0x30
(No auth set)
48
  • Password is not set for the admin account.
0x33 51
  • The local service that's being accessed from the cloud is inactive.
0x90 144
 0x91  145
  • The maximum number of simultaneous connections has been exceeded.
  • It is possible to open not more than 64 connections to one name simultaneously over the cloud.
75 out of 749 found this helpful
