Download files for Keenetic Buddy 4 (KN-3211)
There is no need to download firmware files for your Keenetic. If you already run Keenetic connected to the Internet, upgrading to the latest version of the operating system can be done automatically by enabling Automatic software updates in the General Settings menu. In this case, you don't have to lift a finger to be sure that your Keenetic is always up to date and secure. The operating system will update itself accordingly, even if you have a custom set of components and applications installed. The manual upgrade is also possible by clicking on Install the update in the General Settings menu of the WEB interface.
Before using the utility, be sure to read the article 'Recovery KeeneticOS.'
1 out of 2 found this helpful
