KeeneticOS component description
KeeneticOS supports the following components:
The information is for version 3.7
Languages
English, Danish, Français, Deutsch, Italiano, Polski, Português, Русский, Español, Svenska, Türkçe, Українська A maximum of three web interface languages can be selected in the system. English is a mandatory component.
Basic components
Initial Setup Wizard Step-by-step Internet connection setup
Wi-Fi interface Provides the core wireless functionality
USB interface Allows to use the USB host port on this device
Network accelerator engine Improves routing performance
DHCP server Automatically configures IP settings in the local network
IGMP/PPPoE proxy service The IGMP/PPPoE proxy relays IGMP/PPPoE traffic between network segments
UPnP service Allows the NAT and the firewall rules on this device to be configured automatically
SSH server Allows to gain secure access to the device's command line
Wi-Fi system controller Centralized Mesh Wi-Fi System management
WPA Enterprise Authenticates wireless clients on a RADIUS server
System operating mode
Access point/Extender mode For creating a new Wi-Fi network or to increase the coverage of an existing one
Adapter mode For connection of non-Wi-Fi enabled devices to a wireless network
Repeater/Extender mode For expanding the wireless network of another Keenetic
Internet safety
SkyDNS Safe Internet browsing with SkyDNS
AdGuard DNS Safe Internet browsing with AdGuard DNS
Cloudflare DNS Safe Internet browsing with Cloudflare DNS
Network functions
PPPoE client Allows to establish PPPoE connections from this device
PPTP client Allows to establish PPTP connections from this device
L2TP client Allows to establish L2TP connections from this device
SSTP client Allows to establish SSTP connections from this device
802.1X client Provides login/password-based authentication support over Ethernet networks.
KABiNET ISP authorizer This is the replacement for the PC-based utility used by subscribers of the KABiNET ISP
PPTP VPN server Allows to connect to home network devices using PPTP
SSTP VPN server Allows to connect to home network devices using SSTP
L2TP/IPsec VPN server Allows to connect to home network devices using L2TP/IPsec PSK
IPsec VPN Allows to establish secure IP connections over the Internet
OpenVPN client and server Allows to create OpenVPN tunnels
NetFlow Monitor Gathers information about network traffic forwarded to the Internet and exports flow records to a NetFlow collector
Application-layer gateway (ALG) for FTP Provides customized NAT traversal filters to support address and port translation for FTP protocol
Application-layer gateway (ALG) for PPTP/GRE Provides customized NAT traversal filters to support address and port translation for PPTP/GRE protocols
Application-layer gateway (ALG) for RTSP Provides customized NAT traversal filters to support address and port translation for RTSP protocol
Application-layer gateway (ALG) for SIP Provides customized NAT traversal filters to support address and port translation for SIP protocol
Application-layer gateway (ALG) for H.323 Provides customized NAT traversal filters to support address and port translation for H.323 protocol
Application-layer gateway (ALG) for ESP Provides customized NAT traversal filters to support address translation for the ESP protocol
IPv6 Provides IPv6 protocol support and related services
EoIP tunnelling Allows to create Ethernet over IP tunnels
GRE tunnelling Allows to create GRE tunnels
IP-IP tunnelling Allows to create IP-over-IP tunnels
Wireguard VPN Allows to create Wireguard tunnels
IKE client Allows to establish IKEv1/IKEv2 client connections from this device
Utilities and services
Keenetic mobile application Provides remote management of your Keenetic via the mobile app for Android and iOS
Cloud-based remote control and KeenDNS Required for remote management of your Keenetic using the Keenetic RMM and KeenDNS service
Internet connection status monitoring (Ping Check) Performs ICMP- and TCP-based tests to verify the Internet connection status. Test results may be used to switch between primary and backup connections
Traffic classification engine Provides detailed insights into network traffic with application and user-level visibility
Traffic shaper Provides basic network bandwidth limitation functionality
UDP-to-HTTP proxy (udpxy) Allows home network devices that do not support multicast traffic to watch IPTV channels
Dynamic DNS (DDNS) client Keeps track of dynamic public IP address on this appliance and maps it to a static domain name when changed
SNMP server Allows to gather statistics from this device remotely
Captive portal Application for creating a public Wi-Fi zone with SMS authentication
Packet capture Allows to capture network traffic on router interfaces
DNS-over-TLS proxy Provides domain name resolution via secure DNS-over-TLS protocol
DNS-over-HTTPS proxy Provides domain name resolution via secure DNS-over-HTTPS protocol
USB modems and extension modules
Keenetic Plus DSL - VDSL2/ADSL2+ USB modem Required for Keenetic Plus DSL USB modem functioning
Keenetic Phone Station Required for the operation of Keenetic Plus DECT and Keenetic Linear USB modules
Serial interface for 4G/3G USB modems Enables 4G/3G network connection via a USB modem with a serial interface
CDC Ethernet interface for 4G/3G USB modems Enables 4G/3G network connection via a USB modem of the CDC Ethernet type
NDIS interface for 4G/3G USB modems Enables 4G/3G network connection via a USB modem with an NDIS interface
QMI interface for 4G/3G USB modems Enables 4G/3G network connection via an external - or internal (on select Keenetic models) - USB modem that supports the QMI protocol
USB Ethernet Adapters
Supported chipsets:: ASIX 8817X, Realtek RTL8150/51/52/53, Davicom DM9601/9620
USB to Serial Port Converters
Supported chipsets:: FTDI, PL2303, CP2101/2102, CH340/341, Cypress M8
USB drives
USB storage support Allows a USB drive to be connected to this device
NTFS filesystem Allows an NTFS-formatted USB drive to be connected to this device
FAT32 filesystem Allows a FAT32-formatted USB drive to be connected to this device
HFS+ filesystem Allows an HFS+-formatted USB drive to be connected to this device
exFAT filesystem Allows an exFAT-formatted USB drive to be connected to this device
Ext filesystem Allows an exFAT-formatted USB drive to be connected to this device
SMB file and printer sharing Allows sharing of USB drives and printers with Windows/Apple/Linux computers and other networked devices
AFP file sharing Allows sharing of USB drives over a network with devices that use the legacy Apple File Protocol
Media Server Allows this device to stream content stored on a USB drive to networked digital media players
Download Station Allows to share files on BitTorrent networks, providing an independent lightweight web interface
FTP server Allows file sharing via the FTP protocol
SFTP server Allows secure file sharing via the SFTP protocol
WebDAV server Allows secure file sharing via the WebDAV protocol
Folder permissions control Allows to specify individual user rights for folders on a USB drive
OPKG packages
Open Package support Lightweight package management system based upon OPKG
Kernel modules for file system support
Modules: FUSE, CIFS, NFS, UDF, ISO9660
Kernel modules for USB video support
Modules: USB UVC
Kernel modules for USB audio support
Modules: USB Audio, USB HID
Kernel modules of the Traffic Control subsystem
Schedulers: SCH_HFSC, SCH_INGRESS, SCH_CODEL, SCH_DSMARK, SCH_HTB, SCH_GRED, SCH_PRIO, SCH_RED, SCH_TBF, SCH_SFQ, SCH_TEQL
Classifiers: CLS_ACT, CLS_FLOW, CLS_FW, CLS_ROUTE4, CLS_TCINDEX, CLS_U32, CLS_BASIC
Actions: ACT_MIRRED, ACT_SKBEDIT, ACT_POLICE, ACT_IPT
Ematches: EMATCH_U32, EMATCH_CMP, EMATCH_NBYTE, EMATCH_META, EMATCH_TEXT
USB over IP subsystem kernel modules
USB device sharing solution for TCP/IP networks
Kernel modules to support USB DVB tuners
NOTE: Important! Due to the different hardware configurations of Keenetic routers, we do not guarantee that all components and specific combinations of components available for a particular model can be installed at the same time. In addition, some operating system components are mutually exclusive and cannot work simultaneously.
You can get the recommended set of components by installing the KeeneticOS firmware for your device from the Download Center.
14 out of 15 found this helpful
