KeeneticOS supports the following components:
The information is for version 3.7
Languages
| English, Danish, Français, Deutsch, Italiano, Polski, Português, Русский, Español, Svenska, Türkçe, Українська | A maximum of three web interface languages can be selected in the system. English is a mandatory component. |
Basic components
| Initial Setup Wizard | Step-by-step Internet connection setup |
| Wi-Fi interface | Provides the core wireless functionality |
| USB interface | Allows to use the USB host port on this device |
| Network accelerator engine | Improves routing performance |
| DHCP server | Automatically configures IP settings in the local network |
| IGMP/PPPoE proxy service | The IGMP/PPPoE proxy relays IGMP/PPPoE traffic between network segments |
| UPnP service | Allows the NAT and the firewall rules on this device to be configured automatically |
| SSH server | Allows to gain secure access to the device's command line |
| Wi-Fi system controller | Centralized Mesh Wi-Fi System management |
| WPA Enterprise | Authenticates wireless clients on a RADIUS server |
System operating mode
| Access point/Extender mode | For creating a new Wi-Fi network or to increase the coverage of an existing one |
| Adapter mode | For connection of non-Wi-Fi enabled devices to a wireless network |
| Repeater/Extender mode | For expanding the wireless network of another Keenetic |
Internet safety
| SkyDNS | Safe Internet browsing with SkyDNS |
| AdGuard DNS | Safe Internet browsing with AdGuard DNS |
| Cloudflare DNS | Safe Internet browsing with Cloudflare DNS |
Network functions
| PPPoE client | Allows to establish PPPoE connections from this device |
| PPTP client | Allows to establish PPTP connections from this device |
| L2TP client | Allows to establish L2TP connections from this device |
| SSTP client | Allows to establish SSTP connections from this device |
| 802.1X client | Provides login/password-based authentication support over Ethernet networks. |
| KABiNET ISP authorizer | This is the replacement for the PC-based utility used by subscribers of the KABiNET ISP |
| PPTP VPN server | Allows to connect to home network devices using PPTP |
| SSTP VPN server | Allows to connect to home network devices using SSTP |
| L2TP/IPsec VPN server | Allows to connect to home network devices using L2TP/IPsec PSK |
| IPsec VPN | Allows to establish secure IP connections over the Internet |
| OpenVPN client and server | Allows to create OpenVPN tunnels |
| NetFlow Monitor | Gathers information about network traffic forwarded to the Internet and exports flow records to a NetFlow collector |
| Application-layer gateway (ALG) for FTP | Provides customized NAT traversal filters to support address and port translation for FTP protocol |
| Application-layer gateway (ALG) for PPTP/GRE | Provides customized NAT traversal filters to support address and port translation for PPTP/GRE protocols |
| Application-layer gateway (ALG) for RTSP | Provides customized NAT traversal filters to support address and port translation for RTSP protocol |
| Application-layer gateway (ALG) for SIP | Provides customized NAT traversal filters to support address and port translation for SIP protocol |
| Application-layer gateway (ALG) for H.323 | Provides customized NAT traversal filters to support address and port translation for H.323 protocol |
| Application-layer gateway (ALG) for ESP | Provides customized NAT traversal filters to support address translation for the ESP protocol |
| IPv6 | Provides IPv6 protocol support and related services |
| EoIP tunnelling | Allows to create Ethernet over IP tunnels |
| GRE tunnelling | Allows to create GRE tunnels |
| IP-IP tunnelling | Allows to create IP-over-IP tunnels |
| Wireguard VPN | Allows to create Wireguard tunnels |
| IKE client | Allows to establish IKEv1/IKEv2 client connections from this device |
Utilities and services
USB modems and extension modules
| Keenetic Plus DSL - VDSL2/ADSL2+ USB modem | Required for Keenetic Plus DSL USB modem functioning |
| Keenetic Phone Station | Required for the operation of Keenetic Plus DECT and Keenetic Linear USB modules |
| Serial interface for 4G/3G USB modems | Enables 4G/3G network connection via a USB modem with a serial interface |
| CDC Ethernet interface for 4G/3G USB modems | Enables 4G/3G network connection via a USB modem of the CDC Ethernet type |
| NDIS interface for 4G/3G USB modems | Enables 4G/3G network connection via a USB modem with an NDIS interface |
| QMI interface for 4G/3G USB modems | Enables 4G/3G network connection via an external - or internal (on select Keenetic models) - USB modem that supports the QMI protocol |
| USB Ethernet Adapters |
Supported chipsets:: ASIX 8817X, Realtek RTL8150/51/52/53, Davicom DM9601/9620 |
| USB to Serial Port Converters |
Supported chipsets:: FTDI, PL2303, CP2101/2102, CH340/341, Cypress M8 |
USB drives
OPKG packages
| Open Package support | Lightweight package management system based upon OPKG |
| Kernel modules for file system support |
Modules: FUSE, CIFS, NFS, UDF, ISO9660 |
| Kernel modules for USB video support |
Modules: USB UVC |
| Kernel modules for USB audio support |
Modules: USB Audio, USB HID |
| Kernel modules of the Traffic Control subsystem |
Schedulers: SCH_HFSC, SCH_INGRESS, SCH_CODEL, SCH_DSMARK, SCH_HTB, SCH_GRED, SCH_PRIO, SCH_RED, SCH_TBF, SCH_SFQ, SCH_TEQL Classifiers: CLS_ACT, CLS_FLOW, CLS_FW, CLS_ROUTE4, CLS_TCINDEX, CLS_U32, CLS_BASIC Actions: ACT_MIRRED, ACT_SKBEDIT, ACT_POLICE, ACT_IPT Ematches: EMATCH_U32, EMATCH_CMP, EMATCH_NBYTE, EMATCH_META, EMATCH_TEXT |
| USB over IP subsystem kernel modules |
USB device sharing solution for TCP/IP networks |
| Kernel modules to support USB DVB tuners |
NOTE: Important! Due to the different hardware configurations of Keenetic routers, we do not guarantee that all components and specific combinations of components available for a particular model can be installed at the same time. In addition, some operating system components are mutually exclusive and cannot work simultaneously.
You can get the recommended set of components by installing the KeeneticOS firmware for your device from the Download Center.
